Flapping headlights
HONDA ACCORD
LKYTMR@INSIGHTBB.COM
1988 Honda Accord 207K
My retractable lights oscillate. It used to do it ocassionally and now happens more than 50% of the time. It seems as if the motor has a limit switch or in position switch with a knob to manually rotate the motor by hand. I first thought the in position switch was bad but if that is the case, why would both sides oscillate at the same time. I suspect that the motor is overrunning the in position switch.
Is there a way to slow the motor down? I suspect not. I pulled the fuses and manually rotated the lights up and then found that the Battery light on the dash was on. Are they related? Any ideas here?
I cannot find a schematic for this circuit anywhere. Are these available anywhere?
Is Chiltons the best manual for this sort of thing or does Honda sell something that actual mechanics would use?
I made a small donation but I am not sure what is customary.
Thanks for any help.
Sep 17, 2007 at 9:15 PM
2CARPRO JACK
  • CERTIFIED EXPERT
  • 11,533 POSTS
Try this link
http://www.2carpros.com/kpages/auto_repair_manuals.htm
Goes to Mitchell-On-Demand..... same software the shops use, you will be able to find a schematic there. If both lights do it, I would look for the common denominator
Sep 18, 2007 at 12:00 PM
