1999 Honda Accord Check Engine Light
You can reset this light by holding in the trip indicator button and turn the ket on. When the light stops flashing it is reset.
If it is the check engine light (it has a car image)and it is on, then you must have it reset with a device. Most parts houses have a free reset computer.
Let me know
You need to find what code it has set. I suspect it is an emission code. They are hard to track because of so many components in the emission system and the code is sort of generic to a number of items.
Sometimes a rich engine condition will set an O2 sensor code.
Let me know what code was set. Good Luck
I checked with Auto Zone, where they let me use the device to find out the code. It is P1167, saying Manfacurer contrl, Fuel Air Metering. Then I took my car to another repair shop. Thye checked it again, and got the same code P1167. The shop's computer says that "Primary Hearter Oxygen Sensor (Sensor 1) Heater System Malfunction. But the shop's repair manual (hardcopy) indicates" Fuel injector, fuel pressure, etc". It seems a fuel system problem?
Any suggestions are apprecaied.
Suggested Repair
Retrieve the stored code and do not assume both oxygen sensors failed. For code P1167, inspect the fuel pressure regulator on the fuel rail: with the engine running, remove its vacuum hose and note any change. If there is no change, replace the regulator. Also verify the primary oxygen-sensor heater circuit and wiring if the code persists.
Conversation Summary
A 1999 Honda Accord developed a burning smell and check-engine light after an oil change. A shop reported two failed oxygen sensors, which were replaced, but the light returned with code P1167. One expert questioned replacing both sensors and said the code may indicate a fuel-system issue, specifically the fuel pressure regulator, which should be tested by removing its vacuum hose while the engine is running.
