2008 Honda Accord Noise after starting car
20,500 MILES • 4 CYL • FWD • AUTOMATIC
BBDS
Every morning, the car makes a noise immediately after starting. On cold days the noise sounds like you put an aluminum can on the ground and step on it and smash it. On warmer days, the noise is still present, however not as loud nor does it sound as "crushing". This mostly happens in mornings, when it is the first start of the day. However, again when it is colder, the less abrasive noise will appear after my car has sat for 6-8 hours in my work parking lot. Any ideas? Thanks!!
Apr 12, 2010 at 3:10 AM
KHLOW2008
  • 41,812 POSTS
Hi bbds,
Where is the noise coming from?
Did you check the serpentine belt condition?
Apr 13, 2010 at 10:45 AM
BBDS
I believe the noise is coming from the passenger side of the engine. Is that where my serpentine belt is located?
Apr 14, 2010 at 1:34 AM
DRODR16
Did you ever find out what the problem was? I have the same problem. I am going to take my car into the dealership, I will let you know what they tell me.
Jun 1, 2010 at 3:43 AM
BBDS
I did find out the problem at the dealership last week. It was the variable timing control actuator. there was a bulletin put out by honda america regarding this problem, and the dealership replaced the part by warranty due to this bulletin. since the weather is warm now, they did not hear the noise as loudly, but replaced still. if you search for the bulletin it actually lists the vin #'s involved. also, if you are having problems with early brake wear visit www.girardgibbs.com/hondabrakes.asp
Jun 1, 2010 at 4:33 AM
