2003 Honda Accord Vibration and Pull
DJNY1975
Hey there!
Here's a bit of a timeline to illustrate the background of the problem I am having with my '03 Honda Accord EX V6 Coupe:
December 2005 - Hit a patch of ice, skidded across a city street and hit the left side tires against the left lane curb (front tire took 90% of the impact). Took the car in for regular maintenance, asked that they investigate the ultra-stiff steering that came as a result of the curb incident. This resulted in a Power Steering Rack replacement. Since then, things seemed to be fine, up until about 2 months ago.
Admittedly, I didn't notice the problem (high speed vibration, pull to the left) until about 2 months ago (May 2006), after which I had the car in for another scheduled maintenance and left instructions for the mechanic (Honda dealership) to check out the aforementioned vibration and pull. They discovered that the rear rotors were at the point of replacement, and the back brake was sticking on. Replaced them, knowing that the front brakes aren't too far behind the rear ones in terms of wear...only did the rear ones, as they were in most need of repair.
Got the car back from the mechanic, took the car out on the highway to test...problem persisted. Took the car to a friend (who is a licensed mechanic), who swapped out the front left and rear right wheels, as the wheel that was on the front left had a bend in the rim (as a result of the incident in Dec.). Problem persists beyond tire rotation.
Anyways, long story short, I am still stuck with a heavy vibration at around 90k/h+. as well as a pull to the left at lower speeds and a more drastic pull to the left at high speeds. What should I be asking the mechanic to look for or what type of procedure should I have done when I take it back this week?
Thanks!
Jul 9, 2006 at 5:16 AM
BRUCE HUNT
  • 3,754 POSTS
I have not seen or heard anything about tire alignment. You might be assuming that it was done. Now a vibration can be caused by a tire with a bad cord, but he pull to the left is an indication of alignment. Could be a brake sticking but I doubt it.
Jul 10, 2006 at 2:05 AM
DJNY1975
There was an alignment done at the time of the power steering replacement. Is it wise to have it done again? Would a bent rim cause the car to fall out of alignment?
Thanks!
Jul 10, 2006 at 3:52 PM
Suggested Repair
Have the alignment checked again, since the left pull points to alignment rather than a sticking brake. Also inspect the tires for a bad cord that could cause the high-speed vibration, and address the bent rim.
Conversation Summary
The owner of a Honda Accord EX V6 coupe reports high-speed vibration and a pull to the left after a curb impact that led to a power steering rack replacement and a later alignment. Rear brakes and a bent rim were addressed and wheels were swapped, but the symptoms remained. The expert said the pull indicates an alignment issue and the vibration may come from a tire with a bad cord, while a sticking brake is unlikely.
