2004 Honda Accord Intermittent Vibration noise while accele
130,000 MILES • 6 CYL • 2WD • AUTOMATIC
TENNACCORD04
I have a 2004 Honda Accord and occasionally while accelerating a slight "vibration" type noise is heard and almost felt. Right now it's a very sporadic problem, so it's hard to pin down an exact instance that it does it. Thanks you for any suggestions,
Oct 16, 2010 at 2:37 AM
KHLOW2008
  • 41,812 POSTS
Hi tennaccord04,
Vibrations durring acceleration cna be due to :
1. Engine misfiring.
2. Worn/bad axle shafts
3. Bad engine mounts.
You need to perform testings, visual inspection and mechanical checks to located the source.
Oct 16, 2010 at 4:11 PM
