My car makes a grinding noise while in motion and when you step on the gas. Sometimes it also has an egg smell
Thursday, August 6th, 2009 AT 1:53 PM
F4I_GUY
MECHANIC
The egg smell is most likely due to over-fueling. You are smelling sulphur from your hot catalytic convertor. It can also mean that your convertor has failed as well.
The grinding noise could be a wheel bearing, low brake lining or a rubbing backing plate.
