engine codes P0506
2003 HONDA ACCORD
52,240 MILES • 6 CYL • 2WD • AUTOMATIC
CHISPIS1
The engine surges at idle at times with the ac kicking off. The engine is coding Idle control system rpm low and the first code was the same but with a pending. I was wondering if the is a common thing on these 03 Honda accords. I also was wondering if you could direct me in the rifght direction to fix my problem.
Sep 5, 2008 at 4:59 AM
KHLOW2008
  • 41,814 POSTS
Hi chispis1,
I would suggest cleaning the throttle body and IAC valve as a start. The throttle body and IAC air passages could be dirty and partially clogged causing the low idling rpm and the error code.
Sep 6, 2008 at 5:19 AM
MHARMAN11040
I have this error code on my car and want to know if it is possible to fix it myself or doe sit require major work P0506 Idle Control System RPM Lower Than Expected
Dec 13, 2020 at 1:43 AM (Merged)
  • 55,432 POSTS
This is common when the throttle bore needs to be serviced check out the guide below to fix the problem.
