2003 Honda Accord Clock & Radio lights/ Lighter
2003 HONDA ACCORD
120,000 MILES • 4 CYL • FWD • AUTOMATIC
SOUTHJERSEYJD
Every so often when I hit a bump, the lights that show my radio and clock stop working. I can't see them at all in the dark. Then I'll hit another bump or 2 or more, & eventually one of the bumps will make it come back on again. (I know, I need to stop hitting bumps!)
Also, my husband dropped a dime in the cigarette lighter, and, even though we got the dime out, now we can't use it to charge our phones or anything. It's dead. Do you think that would be a fuse issue?
Any help you can give would be greatly appreciated.
Mar 25, 2008 at 9:22 AM
MERLIN2021
  • 17,250 POSTS
The dime issue is deffinately a fuse, look in your manual for the number! The other problem is a bad connection, and I can't tho I would like to, tell you were it is! You will need to check the body grounds before this get to the point of no return! These are burried all over the car, inside and out, but I would remove the kick panels, and check for loose grounds ...
Mar 25, 2008 at 9:35 AM
