2003 Honda Accord
RAYROD
  • 2003 HONDA ACCORD
  • 4 CYL
  • 42,000 MILES
The ac stop working also the blower.
I remove and check the blower and the blower is OK
I plug it in when I had it ousite and when you turn the ignition swich on the blower move like 2 second then stop the same with the electric fan they start working for about 5 second and stop.
I found the Blower motor resistor but I don't know if really that is the problem it cost about $50 on Honda dealer.
Any suggestion will be appriciated.
Ray
Monday, September 1st, 2008 AT 10:19 PM
KHLOW2008
  • 41,814 POSTS
Hi rayrod,
The blower motor does not use the resistor when operating at maximum speed. I suspect the blower motor to be faulty.
Try vibrating the blower motor housing to see if it continues to work.
Saturday, September 6th, 2008 AT 10:14 AM
