front suspension clunk
65,000 MILES • 4 CYL • FWD • MANUAL
MIKE MUIR
When going over bumps I hear a clunking noise from the front suspension. What is the likely cause and how do I check and verify which component needs replacing. I may be able to do the work myself if standard tools are needed. I am sure a front alignment will be needed afterwards.
Thank you
Mar 19, 2008 at 12:47 AM
BMRFIXIT
  • 19,053 POSTS
Clucking can be the struts or sway bar links here is a guide to help you test to see which one it is please let us know.
https://www.2carpros.com/articles/popping-noise
Please run down this guide and report back
Cheers
Mar 19, 2008 at 12:06 PM
JWW333
I had this problem it was the struts cost me $140.00 for new ones installed them myself :)
Aug 10, 2018 at 6:36 AM
