2002 Honda Accord About transmission
2002 HONDA ACCORD
127,890 MILES • 4 CYL • FWD • AUTOMATIC
YINKEBO
  • 34 POSTS
I noticed that my car, when transiting between the first gear and the next it hesitates, this is more frequent when I want to suddenly increase my speed it doesn't respond to this action as expected and then suddenly shoots forward.
Please, what could be the cause of this.
I sometimes had an accident and changed the engine yet this did not change so I have to suspect the transmission though, at first I suspected the vacuum advance unit.
please, your response will be most appreciated.
Yinkebo
Nov 5, 2008 at 5:29 PM
  • 31,937 POSTS
Hi there,
I would be thinking that it is a problem with a solenoid valve in the transmission, i would get it serviced by a transmission specialist and get them to test and report on this problem, i really needs to have a few test done to pin point this problem,.
mark (mhpautos)
Nov 5, 2008 at 7:42 PM
YINKEBO
  • 34 POSTS
Hi mark,
How do I locate of these solenoid valves on the transmission.
Can I do the servicing as an electrical engineer and have handled solenoids valves before. Just need to look for a socket to use.
Thank you
Yinkebo
Nov 5, 2008 at 10:42 PM
