2001 Honda Accord will not come out of park
100,200 MILES • 4 CYL • FWD • AUTOMATIC
NOLWALK
after start up sometimes the shifter will not move from park
Nov 19, 2008 at 12:36 PM
BRUCE HUNT
  • 3,754 POSTS
This can be a result of one of two problems. The first is the switch for the brakelights and the other is the solenoid at the shifter that releases the stick to move. Normally when you are sitting quietly with the engine running and you step on the brake you will hear the solenoid click to allow movement of the shift lever. One of the two is failing.
Nov 20, 2008 at 1:33 AM
