2001 Honda Accord Transmission or Electical issue
2001 HONDA ACCORD
125,500 MILES • 4 CYL • FWD • AUTOMATIC
AMINAYA
When I start the car and put the transmission in D I get a jerk, when I start driving the others shifts are pretty good unless i have to stop quickly,
then a get a jerk again ,the problem appears to be worse if I have a hi electrical demand (lights, A/C, etc.) then the problem disappears after 15 or 20 mins of driving, and everything works perfectly until the next cold start. Also my dashboard lights always are flashing and if I put the turn lights my instrumen cluster go crazy the same is if I move the shift gear fron D to N or P.
I don't know what to think...
Oct 25, 2010 at 9:38 AM
F4I_GUY
  • 3,302 POSTS
You have a poor electrical ground for your turn signals. I'd start with that first.
Your jerk when you put it into park are most likely one of two things:
Bad engine/transmission mounts
or
Your idle speed is set too high (may be a vacuum leak, or faulty IACV).
Goodluck and thank-you for your previous donation.
Oct 25, 2010 at 11:59 AM
