2001 Honda Accord 2001 Accord shakes with AC on and idle
SUFFAH
MEMBER
2001 HONDA ACCORD
4 CYL
2WD
AUTOMATIC
105,000 MILES
When I have the AC on, my Accord rumbles and shakes when I come to a stop. If I turn off the AC, the car stops shaking.
Could it be the timing belt? My car has 105,000 miles on it and I have never changed the timing belt.
Any advice? Thank you.
Saturday, August 16th, 2008 AT 2:35 AM
2CARPRO JACK
MECHANIC
Not likely. But you should do that belt ASAP. You can try a tune up while you are at it.A/C will cause this due to th efact it loads the engine down more at idle. Also check your engine mounts, if they are worn or sagging you will feel more vibration that if they are good
