2000 Honda Accord stalling
NAVIN08
  • 2000 HONDA ACCORD
  • 6 CYL
  • 135,000 MILES
I had a problem with my Honda accord, I knew the engine mounts were bad so I changed them, but after their was a stalling at around 3000rpm the engine would start shaking and wont go pass 4000rpm.I thought it was the ignition coil, I checked them all and their was one melted so I replaced it. Even after the problem still remains. What can I do to fix this?
Sunday, September 7th, 2008 AT 8:35 AM
KHLOW2008
  • 41,814 POSTS
Hi navin08,
Is the CEL showing?
Did you check the spark plugs?
Check the TPS calibration.
Thursday, May 18th, 2017 AT 11:33 AM
YINKEBO
  • 34 POSTS
How is the TPS re-calibrated. Could it be done with a diagnostic tool or special tools
KHLOW2008
  • 41,814 POSTS
TPS can be calibrated with a voltmeter.
At fully closed throttle 0.5 v
Fully opened throttle 5 v.
YINKEBO
  • 34 POSTS
Thank you for the re-calibration information.
Now at fully closed throttle, if I do not get 0.5V, what do I do next.
2. What would bring my CEL on and using my diag tool it gives me code P1259-manufacturer specific DTC. What could this mean on 2002 honda accord. Though, on idle it performs well but when I rev. It doesn't go beyond 4000rpm.
KHLOW2008
  • 41,814 POSTS
Hi there,
P1259 is a problem with the V-Tec system. When you cannot rev pass 4000 rpm, it is related.
If you cannot get 0.5 v, then you need to unloosen the TPS holding bolt and adjust. If unable to get the reading, replacement is necessary.
