2000 Honda Accord
IWILSON7
  • 2000 HONDA ACCORD
2000 Honda Accord 4 cyl Automatic
I have a 2000 Honda Accord and lately it has been running poorly. It takes a while to build up and then eventually runs smoothly but every time a stop is make, even at a stop sign, it goes into build up mode once more. Today I let someone look at it and they told me all 4 cyl were missing(meaning not running smoothly I assume). So my question is how do I correct this problem, because I have 4 children and no means of transportation. Help me please, and thank you in advance.
Wednesday, July 22nd, 2009 AT 1:35 PM
KHLOW2008
  • 41,814 POSTS
Hi iwilson7,
Is the Check engine light (MIL) showing while driving?
For all cylinders to misfire, possible causes are:
1. Bad spark plugs.
2. Spark plug wires.
3. Distributor cap and rotor.
4. Ignition coil.
Check through the above first.
Monday, July 27th, 2009 AT 12:50 PM
IWILSON7
THANK YOU ALOT FOR YOUR RESPONCE, BUT HOW WILL I BE ABLE TO IDENTIFY IF SPARK PLUG WIRES ARE NEEDED?
Friday, July 31st, 2009 AT 1:52 PM
KHLOW2008
  • 41,814 POSTS
PLug wires can be tested with the aid of an ohm meter.
Test the resistance of each wire between both ends. There should be continuity and not more than 25 k ohms resistance.
Saturday, August 1st, 2009 AT 8:02 AM
