Hi gigi726,
Either the sending unit is not accurate, you have an overheating issue, bad wiring connections or there is insuficient coolant in the radiator.
When thermostat was replaced, was bleeding done correctly?
Remove radiator cap when engine is cold and recheck the coolant level.
SPONSORED LINKS
Wednesday, April 8th, 2009 AT 12:32 PM
