Hi laliag,
Thank you for the donation.
The cause of the problem should be the loss of power as mentioned about the struggling to go uphill.
1. Check the throttle cable adjustment, if the cable is too slack, the throttle would not be able to open fully and constant full throttle would increase the fuel consumption.
Check the ignition timing. If the timing is retarded, loss of power would occur.
If the timing belt had been replaced prior to this occurring, recheck the installation. If it had not been replaced yet, which is overdue for your mileage, check the timing belt tension, a slack in the belt would cause the valve timings to be retarded.
Check the spark plug wires, get them ohmed and if any does not have continuity or resistance is more than 25 k ohms, replace them.
SPONSORED LINKS
Monday, January 11th, 2010 AT 12:12 PM
