Hi everyone,
My 1999 Accord LX 4cyl recently sprung an exhaust leak. Every part of the exhaust is original. The leak occurred at the flange behind the catalytic converter, behind the sensor. I crawled under the car and it doesn't look like any of the three bolts broke, but the two halves did pull away from each other. I sprayed some solution on the area to free rusted parts, but to no avail. The heads of the bolts are pretty well rusted and I was having trouble even getting the wrench on them.
What do you suggest? If I am able to get them off, would I be replacing them with OEM bolts or has the receiving flange rusted too much to use these, requiring a nut and bolt instead? I believe there is a crush gasket there as well that will need replacing. Is that gasket located on the cat side or the oppostie side?
Thanks for your help.
Nov 24, 2007 at 11:27 AM
