1999 Honda Accord D4 light not working
102,600 MILES • 4 CYL • 2WD • AUTOMATIC
ABAHANI74
I own a 99 accord lx v4 and last afternoon the D4 indicatior light on my dask stopped working. The other lights- P,R,N,D3,1,2 work fine. I drove the car 20 miles back and forth yesterday and today. Is this a matter of a blown light or something serious. If it is a blown light would you have any instructions on how I could change it on my car.
Thanks so much,
Hanif
Mar 10, 2009 at 4:43 AM
KHLOW2008
  • 41,812 POSTS
Hi Hanif,
If you have erratic shifting of gears, then it would be a wiring, shift indicator switch or PCM fault. If there are no irregular shifting patterns, then it should only be a blown bulb.
You would need to remove the meter cluster and disassemble the circuit board to replace the bulb.
Mar 15, 2009 at 5:18 AM
