1999 Honda Accord Brake Lights
1999 HONDA ACCORD
296,578 MILES • 6 CYL • 2WD • AUTOMATIC
MTBARWICK
I have replaced bulbs, pedal stop switch and $80 module in trunk and I am still continuing to blow the stop light fuse under hood. I have tried a combination of lights in and out of connectors and the only one that does not blow the fuse is if I do not plug in the module in the trunk. I can't find an apparent ort at the connectors everything seems to be wrapped and taped tight. I did un wrap the wire going to the module but found nothing, Could the gearshift locking solenoid be bad?
Mar 29, 2010 at 8:30 PM
