I am assuming that you are saying when you turn the key nothing happens? Right? If so, replacing the starter may not have been necessary but since that can be eliminated you might want to check the master fuse in the fusebox under the hood. Usually and 80 to 100 amp fuse. Check the connections and be sure they are tight and clean.
After that you are in to the ignition switch.
Dec 18, 2008 at 3:36 AM
