1999 Honda Accord
KSIGMON
  • 1999 HONDA ACCORD
  • 4 CYL
  • FWD
  • 204,000 MILES
For about a year I will be driving down the road and the accord will just die. Sometimes the ABS light will come on right before it does. Lately its been getting worse and sometimes will take many tries before it will crank. It will crank but as soon as you try going it turns off. What could be some possible reason for this or is their any certain kind of test to run to get a better answer for this?
Tuesday, June 17th, 2008 AT 1:47 PM
KHLOW2008
  • 41,814 POSTS
Hi ksigmon,
If you have difficulty cranking, then most probably it is the ignition switch. Did you hear any mild clicking noise just before the engine cuts off
Check and see if the dash lights are working while cranking and after releasing of the key. With engine running, check and see if the ignition seems abnormally warm, wire side.
Tuesday, June 17th, 2008 AT 4:04 PM
KSIGMON
It was the ignition switch, looked it up on th internet and it actually was recalled. Thanks for the help. I got it fixed and the car runs perfect now.
Monday, June 23rd, 2008 AT 10:53 AM
