1998 Honda Accord stalling
JERRY2009
  • 1998 HONDA ACCORD
  • 4 CYL
  • FWD
  • 11,100 MILES
What would cause the engine to just quit as I am driving? When I pull over, it starts right up again. It only happens occasionally, and I do not know the reason. I have cleaned the battery terminals and checked wire connections, but it happened again today.
Monday, August 3rd, 2009 AT 1:05 PM
STEVEW84
  • 673 POSTS
Could be a bad distruibutor, main relay, ignition switch, etc. Anything noticeable when the car shuts off?
Tuesday, August 4th, 2009 AT 7:24 AM
JERRY2009
Nothing when it shuts off. Thanks. I'll explore your suggestions.
Tuesday, August 4th, 2009 AT 3:46 PM
STEVEW84
  • 673 POSTS
You have to see what is missing when the car shuts off. Fuel, spark, or timing is what it is end up being. Should have a fuel gauge hooked up, spark tester, and also check for codes.
Tuesday, August 4th, 2009 AT 4:29 PM
