HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Honda
Accord
Engine
Symptoms
Idle Rough
SPONSORED LINKS
1998 Honda Accord ROUGH IDLE
BILL HUST
MEMBER
1998 HONDA ACCORD
Engine Mechanical problem
1998 Honda Accord 4 cyl Front Wheel Drive Automatic
THIS CAR IDLES REALLY ROUGH WHEN A/C ON WHEN STOPPING AT RED LIGHT OR STOP SIGN, ETC. ANY HELP WOULD BE APPRECIATED.
Tuesday, June 24th, 2008 AT 1:24 AM
KHLOW2008
MECHANIC
Hi bill hust,
Help us to help yourself.
When you say rough, what do you mean? Idling rpm very high, very low or both, ie, hunting up and down?
SPONSORED LINKS
Tuesday, June 24th, 2008 AT 9:45 AM
BILL HUST
MEMBER
THE RPM IS REALLY LOW HE SAYS IT ACTS LIKE IT WONTS TO DIE. WHEN GIVEN THE GAS IT STRAIGHTENS UP AND RUNS FINE.
Tuesday, June 24th, 2008 AT 1:53 PM
KHLOW2008
MECHANIC
Hi bill hust,
Ok, your idling system need some cleaning.
Use some carb cleaner to clean the throttle body, idle adjust screw and EACV and readjust the idle speed.
Tuesday, June 24th, 2008 AT 3:26 PM
Please
login
or
register
to post a reply.
Related Engine Idle Rough Content
1998 Honda Accord Runs Rough, Idles Rough
Engine Performance Problem 1998 Honda Accord 6 Cyl Front Wheel Drive Automatic 99k Miles I Have A 1998 Honda Accord V-6 Auto. It Has...
Asked by
Not Too Bright
1 ANSWER
1998
HONDA ACCORD
GUIDE
Rough Engine Idle
A rough engine idle condition is a common issue that many drivers face often indicating underlying problems within the engine, fuel or ignition system. We have created this...
1998 Honda Accord Rough Idle/missing
Greetings, I Enjoy Reading All Your Comments. I Have A 98 Honda Accord. 222k Miles. Car Has Rough Idle. Coded Upstream O2 Sensor....
Asked by
lmhuff
1 ANSWER
1998
HONDA ACCORD
My Son Has This Car, Has Been Well Maintained. It Runs Like A Sewing Machine When Cold, But When It Reached Normal Running Temperature...
Asked by
nixacody
1 ANSWER
1998
HONDA ACCORD
P0170, P0171 Codes - Shuggish At Slow Speeds. Rough...
Hi, I Have A 98 Accord, 4cl, 2.3 Lx With 165,000+ Miles These Are The Symptoms - Getting Error Code P0171 - System Too Lean (...
Asked by
hari v
1 ANSWER
1 IMAGE
1998
HONDA ACCORD
Engine Missing/idling Rough
Where To Start. I Have Two Huge Holes In My Radiator And It Leaks Bad. I Have Been Very Cautious And Stop Frequently To Fill It With Water....
Asked by
radtodd1
1995
HONDA ACCORD
VIEW MORE
SPONSORED LINKS
Vacuum Leak Symptoms
Vacuum Leak Test and Repair
Vacuum Leak
Online car repair manuals
