1997 Honda Accord over heated
FLYGUYY777
  • 1997 HONDA ACCORD
Engine Mechanical problem
1997 Honda Accord 4 cyl Front Wheel Drive Automatic
my mother over-heated a 1997 accord se about a yr ago. She gave me the car if I can fix. Where should I start?With the head gasket?I was told that when you replace a head gasket you should take the head into a shop to be inspected for cracks and warps, is this true, one more thing before I take the head off what is the best way to get the head bolts off without stripping or breaking them, I here they r brittle because of the heat
Monday, March 15th, 2010 AT 12:06 PM
F4I_GUY
  • 3,302 POSTS
You should definately have the head sent to a machine shop to be checked for cracks. The best way to take off head bolts is just to crack them loose carefully with a johnson bar and the PROPER sized socket. Yours will be a 14mm.
Monday, March 15th, 2010 AT 6:09 PM
