1997 Honda Accord High pitched humming, worse when accelera
120,000 MILES • 4 CYL • FWD • MANUAL
AMBERROSESHOPS
All of a sudden my 97 Honda Accord started making this high pitched humming sound. Not squeaking, or clanky, it sounds almost exactly like what low power-steering fluid sounds like, but I'm pretty sure its not that because it doesnt make any noise when i turn the wheel. It gets worse when I accelerate. It is not running any hotter than normal, the oil is fine, it shifts fine, and I havent used the AC in months. Help?
Feb 27, 2010 at 11:45 AM
KHLOW2008
  • 41,812 POSTS
Hi amberroseshops,
Noises are impossible to diagnose without the physical vehicle.
You would need to locate the source and check the area for possible faults. A rubber hose acting as stethoscope would help in isolating the source.
Feb 27, 2010 at 9:03 PM
