Does the check engine light come on? Would you say the engine itself is running rough when cold?
You are playing russian roulet with the timing belt, but I don't suspect it is causing your problem.
You might want to check the engine motor mounts and see if one of them might have given out. Please think about the questions above and reply to them. Thanks!
SPONSORED LINKS
Wednesday, April 30th, 2008 AT 3:35 PM
