Saludos
tengo el problema que tiembla mucho el motor y cheque lsi corta la corriente en las bujias y la bujia dos no corta que sera los cables o bobinas, bujias no lo se espero su respuesta
Tuesday, October 12th, 2010 AT 9:08 PM
MECHANIC
Hi there,
The language translator is not making things easy here, if you have a rough idle problem, have you done a comp test and done a full tune up as yet, also have a scan done to check for any set fault codes, start here.
