1997 Honda Accord Dim Dash and Stall
DANZFOTOG
1997 Accord 4 cyl. 265,000 miles -- manual transmission
Background problem: sometimes won't start in damp/wet weather unless I blowdry the distributor cap, after removing plugs. Otherwise, no problems starting.
Current situation:
After a short rain, I moved the car into garage -- it started up no problem, so I thought nothing of it. Next day, car wouldn't start -- just got clicking noise when I'd turn the key. Turns out after testing, the battery wasn't holding a charge all of a sudden.
I replaced the battery with new one. The car fired up immediately. After about 75 minutes of driving (30 min., short break, then 45 minutes), I noticed that with the headlights turned on, the speedometer & odometer would fall to 0 (not be engaged) so I couldn't tell how fast I was driving. Turn off the lights and the speedometer/odometer come back to life.
However, if I kept driving, eventually all the dashboard lights dim, speedometer/odometer falls to 0, and then the final thing is the car starts to jerk as if to stall.
I'm guessing either I have a bad battery, a bad alternator or something else I'm not thinking of. Any ideas how to localize the problem?
Thanks in advance.
Jul 26, 2007 at 6:51 PM
BRUCE HUNT
  • 3,754 POSTS
That sounds to me like the alternator is having problems. First I would check the grounds and make sure they are secure and clean. Many car parts stores will test the alternator for you and not charge for the service.
Jul 27, 2007 at 1:25 AM
Suggested Repair
Check that the grounds are clean and secure, then have the alternator tested at a parts store.
Conversation Summary
A 1997 Honda Accord with 265,000 miles sometimes would not start in damp weather unless the distributor cap was dried. After rain, it only clicked and the battery would not hold a charge. A new battery restored starting, but after driving the speedometer and odometer dropped to zero with the headlights on. Continued driving caused the dashboard lights to dim, the gauges to fail, and the car to jerk as if stalling. The expert suspected a failing alternator and recommended checking the grounds and having the alternator tested.
