1996 Honda Accord Vehicle Speed Sensor
LARITALANG21
  • 1996 HONDA ACCORD
  • 4 CYL
  • 215,000 MILES
My card recently started jerking when I go to accelerate mainly after braking. I took it to a mechanic who also did a diagnostic check and told me my vehicle speed sensor needs to be repaired. The jerking also causes my odometer and speedometer to work when it feels like it and also makes the shift levels on the dash flash back and forth. Is the sensor the problem? Also, where is it located and is it hard to get to?
Tuesday, March 10th, 2009 AT 2:46 PM
F4I_GUY
  • 3,302 POSTS
Yes, a faulty VSS signal can cause transmission problems. If the transmission does not know the vehicle speed it may cause improper shifts.
The VSS should be located on top of the transmission housing. It is a 3 wire plug.
Tuesday, March 10th, 2009 AT 4:17 PM
