Friday, January 11th, 2008 AT 1:05 AM
Hi, I just had timing belt, water pump and the crank sensor replaced on my car by a mechanic. Since then, the engine sound is changed and when you are sitting behind the wheel, I can feel the vibration in my hands. The mechanic, who is also my friend, tells me that the engine mounts need to be replaced. Any ideas what causing the extra vibration? Thanks
