1996 Honda Accord EGR valve
USAKANGA
  • 1996 HONDA ACCORD
  • 4 CYL
  • 185,000 MILES
Engine code 401. Egr insufficiant flow. I have no vaccum to the valve. I have a scanner that shows no variable on the voltage to the valve. I am not real familiar with the components on this car.
Friday, March 20th, 2009 AT 7:33 PM
BMRFIXIT
  • 19,053 POSTS
Very common to see EGR ports and passages clogged
TECHNICAL SERVICE BULLETIN
Model(s): 1994-1996 Honda Accord
SERVICE INFORMATION
If the MIL is on along with DTC P0401 (insufficient EGR flow) or DTC P1491 (EGR system malfunction) on a '94-96 Accord or '95-96 Odyssey, do these checks:
1. From the PGM Tester freeze data display, check the EGR VLS (exhaust gas recirculation valve lift sensor) voltage.
? For DTC P0401, if the EGR VLS reads more than 3.0 V, clean (unclog) the EGR passages. If it reads less, go to step 2.
? For DTC P1491, if the EGR VLS reads more than 2.0 V, replace the EGR valve. If it reads less, go to step 2. 2. Disconnect the vacuum hose from the EGR valve, and attach it to a vacuum gauge.
3. Backprobe the RED wire in the EGR control solenoid valve connector, then start the engine, and let it idle.
4. While watching the vacuum gauge, apply and remove ground to the RED wire 10 times.
? Does the gauge read 6 inches of vacuum within 1 second of grounding the RED wire? YES - Go to step 5. NO - Replace the EGR control solenoid valve, and clear the DTC.
5. Remove the backprobe, and apply 6 inches of vacuum to the EGR valve.
? Does the EGR VLS reading go to 1.2 V and stay there? YES - Replace the EGR valve, and clear the DTC. NO
Saturday, March 21st, 2009 AT 5:21 AM
