When the overheating issue takes control of your vehicle it is hard to shake. The mixing of the oil and coolant is a serious issue. I caution throwing good money after bad. For instance, you have had the head gasket replaced but this did not fix the problem. Now either you need to find another mechanic or another vehicle. The head gasket was either put on improperly OR the problem resides in the block. The block might have a slight crack. I would suspect the block at this point. A leak down test properly administered might be able to pinpoint the issue. Prognosis is not good. Good luck!
SPONSORED LINKS
Thursday, May 1st, 2008 AT 6:07 PM
