1996 Honda Accord
CYOKOFICH79
  • 1996 HONDA ACCORD
Engine Performance problem
1996 Honda Accord 4 cyl Manual
my car is making like a putt-putt noise and is blowing alot of smoke out of my exhaust when I start it up. When I give gas and go it doesn't have as much power as it should. It has some hesitation. Recently I had a new cooling system installed and an oil change as well as new valve cover gasket. The mechanic told me I had oil leaking into where my spark plugs go so thats why he replaced the gasket and the ones surrounding where the spark plugs go. He cleaned off my wires because they had oil on them as well. Do you think my car is doing this because I didn't replace the spark plugs and wires? Also, even though I had a new radiator and thermostat and o-ring installed, my temperature guage still is going to the overheating zone. What could be the cause of this. The mechanic told me he put the car on a machine that told him my engine is not getting too hot. It goes up to 219 degrees and my fans kick on just fine but he doesnt know why the guage still reads like its overheating.
Saturday, June 21st, 2008 AT 10:23 PM
KHLOW2008
  • 41,814 POSTS
Hi cyokofich79,
If the misfiring happens only when cold, the plug wires and spark plugs could be the cause or there is compression leak due to a blown head gasket.
If the temp gauge is registering a high reading,
1 Either the sensor or gauge is not accurate, the grounds are not good
2. There are air pockets in the cooling system.
3. The engine is really overheating.
Sunday, June 22nd, 2008 AT 12:52 AM
