1995 Honda Accord 95 Honda Accord Overheating
MRCWEBSTER71
  • 1995 HONDA ACCORD
  • 4 CYL
  • 130,000 MILES
1995 honda accord lx 4 cyl. Overheating. Replaced radiator cap. Replaced thermostat (tried two that are new), flushed radiator, checked water pump (pressure on lower radiator hose and no leaks from seep holes), Finally changed head gasket, intake, exaust, etc. Cooloing fans come on. Also there is no heat coming from vents when heat is turned on, I did open the air release valve to the right of the thermostat to release any air that might be in the system, I changed the oil filter, spark plugs, And after all of this I still have the original overheating problem. There were no signs of head being cracked or fluids in the cylinders. Any suggestions? Maybe reflush entire system with a good cleaner?
Monday, January 14th, 2008 AT 3:54 PM
BLACKOP555
  • 10,371 POSTS
First you may have a offset on the ignition timing, rich fuel mixture, or plugged or bent radiator cooling fins.
Also take off the pump and manually check the impellers on it to make sure they move freely and are not worn.
Monday, January 14th, 2008 AT 6:08 PM
