1995 Honda Accord
JERODDAWSON
  • 1995 HONDA ACCORD
  • 4 CYL
  • FWD
  • 143,341 MILES
What cause a stutter when taking off
Thursday, March 4th, 2010 AT 7:34 PM
Hesitation, chugging, bogging, lack of acceleration etc, could be cause by one of the following below.
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Thursday, March 4th, 2010 AT 11:47 PM
