1994 Honda Accord Metal Grinding
203,000 MILES • 4 CYL • FWD • AUTOMATIC
BRIAN.INGRAM
The noise comes from the right front of the car. It sounds like metal grinding. It makes a noise when turning, dirving straight, or just getting in and out of the car. I can push down on the right-front side of the car and produce the grinding sound. It was not so bad when the weather was cold, but now it has gotten worse. Do you have a diagnosis and a rough cost estimation?
Thanks,
Embarrassed Driver
Mar 22, 2009 at 7:02 AM
KHLOW2008
  • 41,812 POSTS
Hi Brian,
You have a bad ball joint some where and it could be:
1. Lower arm ball joint.
2. Upper arm ball joint.
3. Steering rack end.
4. Tie rod end.
The cost would depend on which item needs to be replaced.
Mar 23, 2009 at 5:10 AM
