1994 Honda Accord i dont know what the prob is
180,000 MILES • 6 CYL • FWD • AUTOMATIC
HONDA-MAN21
i have a 1994 honda acord and it wont stop revin up when itis in park or drive and i dont know what the problem is but it still drives but wont stop revin up
Jun 1, 2009 at 12:11 PM
KHLOW2008
  • 41,812 POSTS
Hi honda-man21,
I believe what you are experiencing is commonly termed as surging. This is caused by excessive air getting past the throttle body and possible causes are :
1. Low coolant level. This would prevent the Fast Idle (cold start ) Valve from closing and allowing evcessive air getting through.
2. Faulty FIV
3. Faulty EACV (IAC) valve.
Clogged coolant hoses to the EACV and FIV would have same results.
4. Vacumn leakages. PCV, faulty solenoids, dislodged hoses, brake booster
5. Idle screw adjusted out of specs.
Is the Check Engine Light showing?
Jun 3, 2009 at 5:47 AM
