The abs light turn on when I turn my car on how do I fix that?
Wednesday, April 1st, 2009 AT 1:07 PM
ARC_55
MEMBER
Many of the dash lights will stay on for a short second after starting the car. If they stay illuminated then that means you have an ABS fault. This would require the car to be scanned for any possible abs codes and following diagnostic procedure.
SPONSORED LINKS
Wednesday, April 1st, 2009 AT 1:20 PM
OBXAUTOMEDIC
MECHANIC
Have you checked your fluid level? You will need to have codes read. To determine the exact sensor or sensors.
