1993 Honda Accord Shift Position Swith
250,000 MILES • 4 CYL • 4WD • AUTOMATIC
RPIMENTEL25
  • 8 POSTS
Hello , so my check engine light wouldnt turn off so i took it to a friend of mine that has a scanner. His scanner showed a Code #6 and said shift position switch. And i am wondering where is that located exactly? And it is also turning off when i do a sudden stop or reverse, would that be because of the shift position switch? Need help please!
Thank you
Jul 28, 2009 at 2:35 PM
BLUELIGHTNIN6
  • 16,542 POSTS
yes it could cause that, it is located under the right side of the floor console, on the base of the gearshift
Jul 28, 2009 at 2:50 PM
RPIMENTEL25
  • 8 POSTS
[quote:72eb6fcc64="bluelightnin6"]yes it could cause that, it is located under the right side of the floor console, on the base of the gearshift[/quote:72eb6fcc64]
Ok so its on the passengers side on the gear shift console? How can i fix that? Do i need to replace it or what exactly? Please help.
Thank you
Aug 7, 2009 at 3:32 PM
BLUELIGHTNIN6
  • 16,542 POSTS
yes you will need to replace it
Aug 7, 2009 at 3:52 PM
RPIMENTEL25
  • 8 POSTS
[quote:1d710a7d52="bluelightnin6"]yes you will need to replace it[/quote:1d710a7d52]
Would you know where i can get one? And generally what are the price for one of these?
Thank You
Aug 8, 2009 at 6:04 AM
BLUELIGHTNIN6
  • 16,542 POSTS
for used parts search sites such as craigslist.com and ebay.com. also call around your local salvage yards. to purchase new one contact local dealer. they can give you price estimate for the part as well.
Aug 8, 2009 at 6:17 AM
RPIMENTEL25
  • 8 POSTS
Thank you, another question if my car has been wasting alot of water what could the problem be? My dad thinks it might be the radiator cap or the little bottle connected to the radiator idk what its called but that has the cap cracked as well? What can it be you think?
Thank You
Aug 9, 2009 at 6:46 PM
BLUELIGHTNIN6
  • 16,542 POSTS
if either of the caps are cracked then yes it could leak there. are there any visible signs of leaking coolant? puddles under ground, wet components..etc..?
Aug 10, 2009 at 2:51 PM
RPIMENTEL25
  • 8 POSTS
[quote="bluelightnin6"]if either of the caps are cracked then yes it could leak there. are there any visible signs of leaking coolant? puddles under ground, wet components..etc..?[/quote
No, there is no signs of leaking coolant. Everytime i turn off the car the fan stays on for a while...thats normal though right? And i just replaced the radiator cap but the overflow bottle is cracked and almost peeling off from the top and even after i replaced the radiator cap i still noticed that the car is wasting too much water..
Aug 11, 2009 at 6:18 AM
BLUELIGHTNIN6
  • 16,542 POSTS
yes, thats normal. if overflow tank is cracked then it definitely needs replacing
Aug 11, 2009 at 7:10 AM
RPIMENTEL25
  • 8 POSTS
[quote:84feb7f694="bluelightnin6"]yes, thats normal. if overflow tank is cracked then it definitely needs replacing[/quote:84feb7f694]
Ok thank you, and about the shift position switch i went to the salvage yard and got the shift postion switch or so i think...if you know a way i can get a picture of it can u send me the link? id appreciate it... Because i looked on the internet but couldnt find 1.... but for safekeeping i took both switches and everything from it and replaced it already and i took off the battery to reset it and everything and the check engine sign is still lit..would you have any other idea what it could be?
Thank You
Aug 11, 2009 at 9:43 AM
