1993 Honda Accord Car Stalls and doesnt want to start back
211,400 MILES • 4 CYL • FWD • MANUAL
SEAL6925
My honda accord will die when I am actually driving down the road. I have tried to pop the clutch to try to see if that might get it running again. When I try to start the car after it dies sometimes it starts right back up other times it takes a while almost like it is flooded. the battery, terminals, wires, distributor, spark plugs, and spark plug wires are all brand new put them in less than 6k miles ago if you could give me a good estimate as to what is going on i would appreciate it
Apr 2, 2009 at 2:04 AM
F4I_GUY
  • 3,302 POSTS
When it doesn't start check to see if you are getting STRONG spark. Strong spark should be bright, usually white/blue and should easily jump double the gap of your normal spark plug.
If you have strong spark, measure fuel pressure.
Apr 2, 2009 at 11:37 AM
