1993 Honda Accord 93 Honda Clutch Problem
360,000 MILES • 4 CYL • FWD • MANUAL
TBEAL11
My clutch went the other day meaning i put it to the floor and wouldn't go into any gear is was snapping to the floor and sticking down, so i was looking at the master clutch cylinder seeing it was leaking down the inside firewall so i figured this the problem and replaced it today. Got the new unit back in still snaps to the floor and when i pumped the clutch by hand to bleed it i get no pressure and i got no fluid to the bleeder on the slave cylinder. So i cracked open the inlet pipe on the Slave cylinder and i get fluid there when i pump so i close that back up and try again at the bleeder and i get nothing still does this mean the slave cylinder is bad or is there another problem. Thank you for the help
Aug 9, 2010 at 2:30 PM
  • 75,988 POSTS
Replace the clutch slave/servo
Aug 9, 2010 at 2:33 PM
TBEAL11
this will cause the clutch to snap and stick down if the slave is bad which i was pretty sure. thank you for the help
Aug 9, 2010 at 2:50 PM
