1992 Honda Accord car shake at idle
142,000 MILES • 4 CYL • FWD • AUTOMATIC
JUNMAX
The car starts and runs fine, it has a lot of power when driving, it can goes up the hill fast. The only one problem is the car shake when at idle. I can fell the shake from steering wheel to engine. I suspect is vacuum leaks. Anyone has other idea that can pinpoint the problem?
May 25, 2010 at 5:54 PM
  • 31,937 POSTS
Hi there, start with the full tune up and check for any unresolved fault codes, ensue that the base idle is set correct and as you mentioned check for any vacuum leaks, start here.
mark (mhpautos)
May 25, 2010 at 9:10 PM
FSGMAG
another solution could be broken
motor mounts
Jun 7, 2010 at 5:32 PM
