1990 Honda Accord slow take off
JBINLC
My 1990 Honda Accord takes off from a stop very slowly. I recently did some work on the distributor which solved one issue. I think I may have damaged a vaccum line to the fuel injector. Could this cause it to run bad and have slow pick up? It runs fine after it is up to speed.
Aug 10, 2006 at 12:26 AM
SYNCRAIT
  • 235 POSTS
what kind of work did you do to the distributor? you may have spun back the timing which would give you poor performance....also what makes you think you damaged the vacuum line....good luck :)
Aug 10, 2006 at 12:46 AM
JBINLC
I fell on the vaccum. All I did in the distributor was change a wire from the ignition coil to the ignitor.
Aug 10, 2006 at 1:08 AM
