1990 Honda Accord OVERHEATING
WILLAN1
  • 1990 HONDA ACCORD
  • 4 CYL
  • FWD
  • 130,000 MILES
My fans only work when I shut the car off after being driven. They do work when the a/c is on. I changed the fan radiator switch and bled the system of air. Is there anything else I can do to get the fans working while the car is running? Thanks
Friday, April 4th, 2008 AT 12:46 PM
I changed the fan radiator switch-this one could be for the gauge. Try checking the engine coolant temperature sensor
Friday, April 4th, 2008 AT 4:17 PM
WILLAN1
Is it located under the distributor?
Friday, April 4th, 2008 AT 5:26 PM
The coolant temperature sensor is located near coolant outlet housing see below
https://www.2carpros.com/forum/automotive_pictures/12900_cts1_2.jpg
Friday, April 4th, 2008 AT 5:45 PM
Related Engine Overheat Content
