When was the last time it had a major tune-up?
Warm the engine up for 5 mins. Shut it down look inside the throttle bore do you see fuel dribbling from the main nozzle-if so time to rebuld.
If not-test the coolant temperature sensor/idle air controller/throttle position sensor.
Most Common Fuel Wasters:
Loose or missing gas caps. 17 percent of U.S. Vehicles have a loose or missing gas cap. This allows an estimated 147,000,000 gallons of gas per year to evaporate into thin air.
Underinflated tires
Faulty thermostats
Worn spark plugs
Malfunctioning engine controls
Poor wheel alignment
SPONSORED LINKS
Sunday, February 24th, 2008 AT 5:06 PM
