1988 Honda Accord grinding noises
349,876 MILES • 4 CYL • FWD • MANUAL
COWBOYBLUE82
grinding noises whin i turning and when i stop the car will push down and there will be a grinding noise then to there is a small leak on the power stering cup. and i need help? i dont have a good edu on cars but i get by.
Dec 22, 2008 at 7:05 AM
JIMMYL645I
  • 39 POSTS
if your observing and hearing a sound while your turning, i would suggest you change your powersteering fluid. if the steering fluid isn't Genuine Honda fluid sometime it can cause corrostion and make the powersteering fail prematurely.
sometime simply changing the steering fluid will rid of all your squeaking and grinding-
also if the PS fluid is showing signs of leakage, you should have that checked out by a local honda/acura shop.. if at some point you run out of fluid completely you can servely damage the whole power steering assembly. you dont want that to happen.
hope this helps, best regards to you my friend.
JL feedback is greatly appreciate
Dec 23, 2008 at 2:30 PM
