1988 Honda Accord Expansion valve location
1988 HONDA ACCORD
114,000 MILES • 4 CYL • FWD • AUTOMATIC
BILLGREGO
I need to know the exact location of the AC expansion valve on my 1988 Honda Accord LXi model. I have a repair manual which does not show anything regarding the AC system. The engine is fuel injected with an automatic transmission. I know it is located in the housing under the dash. Can it be removed without pulling the complete housing down? Could there be a possibility of cutting into the blower housing to reach it and then reseal the cut out? I know the valve is bad because of pressure readings. Any help will be sincerely appreciated.
billgrego
Jun 29, 2008 at 1:12 PM
KHLOW2008
  • 41,814 POSTS
Hi billgrego,
You need to discharge the AC system and remove the evaporator to replace the expansion valve. No two way about it.
No need to remove the dash though.
Jun 30, 2008 at 2:43 AM
SPEED2000
  • 9 POSTS
which valve do you use to recharge the system?
Aug 7, 2008 at 2:46 AM
