The car shows a warning of High Transmission Temperature?
42,000 MILES • 1.5L • 4 CYL • 2WD • AUTOMATIC
ADIL IJAZ
Its gear shift is malfunctioning. As I press the gas pedal, instead of accelerating it makes sounds and does not move. And when it is moving it skips some gears. Like it shifts from 2 to 4 skipping 3. I have driven about 2-4 km while having this issue. It is a Honda Vezel Hybrid with DCT transmission. The milage is 42000 km.
Apr 26, 2023 at 10:14 AM
  • 55,721 POSTS
We should run the codes to see what comes up.
Here is a guide to help:
Please go over this guide and report back.
Apr 27, 2023 at 9:13 AM
ADIL IJAZ
I took the car to the mechanic. He found out that the car has an issue which shows an error code P2858. That mechanic didn't know anything about DCT. So, I did my own research and opened the compartment where clutch oil is placed. Since it has dual clutch, there were two bottles. One was completely empty. We put new oil in it. Now the error code is gone. The vehicle is bit better but still it's not completely fine. I just brought the vehicle back home and I am not driving it because I think it's now good to drive it in this condition.
Apr 27, 2023 at 12:38 PM
  • 55,721 POSTS
You must have a leak in one of the secondary cylinders, can you look under the transmission to confirm?
Apr 29, 2023 at 4:05 AM
ADIL IJAZ
Yes, there is an oil leakage.
Apr 29, 2023 at 12:54 PM
  • 55,721 POSTS
Yep, it sounds like you found the problem. Is this a euro car? I don't show a dual clutch in my information, nevertheless the transmission will need to be removed and the secondary cylinder replaced.
Apr 30, 2023 at 3:48 AM
